Browse Forums Flooring & Floor Covering 1 Nov 12, 2004 8:20 am As a temporary measure I want to make the particle board floor in a spare bedroom (upstairs) more attractive. What bases are suitable for particle board (oil based or water based)? What brands do you recommend for paint or stain or polish for particle board floor? Can you use the natural oil finishes (organoil) on particle board?
I will have a beautiful mat on the floor. Outside the room are polished boards, a similar pale colour to the particle board. Thanks! Re: decorating particle board floor 2Nov 16, 2004 8:17 pm HEY THERE A MANY WAYS YOU CAN GO AND HERE THEY ARE
1. A SOLID COLOUR TO MATCH YOUR FLOOR BOARDS IS THE FIRST OPTIONS WITH THOUSANDS OF COLOURS TO CHOOSE FROM YOU SHOULD NOT HAVE ANY PROBLEMS AND THE PAINT TO USE IS ANY SELF PRIMING EXTERIOR PAINT (GLOSS) LIKE DULUX X10 OR WATTYL SOLAGARD ETC.... THESE ARE NOT FLOOR GRADE PRODUCTS BUT CAN LAST QUITE A WHILE. 2. ANOTHER NICE FINISH I HAVE SEEN IS WATTYL EXTERIOR STAIN ITS A SEMI TRANSPERENT STAIN THAT LOOKS GOOD AND CAN BE COATED WITH A CLEAR AFTERWARDS 3. IF AN OIL FINISH IS WHAT YOU WANT FEAST WATSON HAS A PRODUCT CALLED CHINA WOOD OIL A NICE PRODUCT THAT CAN BE TINTED WITH OTHER PRODUCT PROOFTINT FOR A TOUCH OF COLOUR THERE ARE MANY FINISHES YOU CAN DOO ON FLOORS JUST ASK YOUR LOCAL PAINT SHOP AND THEY SHOULD GIVE YOU A FEW IDEAS CHEERS EGGENZ 2004 Thanks for clarifying. Sorry I misunderstood your point 7 7651 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17220 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18019 |
