Browse Forums Flooring & Floor Covering 1 Apr 24, 2024 12:14 am Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym and to just leave the concrete To cope with the different levels (to be safe) - I've asked for a sliding door (I was worried that a hinged door would not swing properly if the floors are level to begin with). Or is there a good way to do this and keep it hinged? But also in general I'm now thinking how do I make sure the rubber gym flooring is as flush as possible to the hallway? Yet to ask the builder, but want to check what flooring is under the sliding door? Any thoughts - no idea what exactly to do and what is normally done? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 6493 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16044 |
