Browse Forums Flooring & Floor Covering Re: Best carpet deals in perth 2May 16, 2023 7:29 am Have you tried Parry's or Carpet Court? It takes half your life before you discover life is a do-it-yourself project. - Napoleon Hill 1 16286 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6823 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7732 |
