Browse Forums Flooring & Floor Covering 1 Apr 05, 2021 7:08 am I was wondering if you can use flooring adhesive overtop of the Agnew's Water Putty floor filler? I am looking at using the floor filler to fill some imperfections in my existing timber floor and want to glue down engineered floor boards on-top. I will be using a polyurethane based flooring glue, or would there be a more suitable glue to use? Cheers Re: Agnew's Water Putty Floor Leveller 2Apr 05, 2021 8:21 pm What sort of imperfections and what size are you talking? What sort of existing flooring do you have and how is it fixed? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3438 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17080 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17913 |
