Browse Forums Flooring & Floor Covering Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16904 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4583 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12965 ![]() |
