Browse Forums Flooring & Floor Covering 1 Oct 28, 2020 12:57 pm I'm replacing my tiles in my kitchen, i live in a high rise apartment so i assumed the tiles were laid direction on concrete. but after removing 3 tiles i noticed that there is a rubber underlay beneath my tiles. i'm looking for advice for the 3 possible scenarios: Option 1 remove the tiles from the rubber underlay as best as i can, then re lay new tiles with new adhesive over existing rubber underlay. Option 2 completely remove tiles and rubber underlay, then re install new rubber underlay, then install the new tiles with new adhesive over new underlay. If i were to go down this path, where do i get the rubber underlay for tiles specifically? how do i lay the underlay, do i use a specific glue? Option 3 completely remove tiles and rubber underlay, then re lay new tiles with new adhesive on the concrete floor. any help or advice would be greatly appreciated. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: installing advice for tiling my kitchen 2Oct 28, 2020 6:22 pm Option 3 is a no go. You will find the acoustic underlay is a requirement in multifloor developments. That leaves you with option 1&2. Obviously 1 will be the cheapest but that assumes you can get the tiles up without damaging the underlay which I can imagine being a challenge. Option 2 will be the most expensive but will probably give you the best job and may even be quicker in the long run. Most tilers should be able to organise the whole job for you. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: installing advice for tiling my kitchen 3Oct 29, 2020 2:09 pm thanks thanks for your advice. ill be going with option 2 as suggested, i think is the best way also much quicker with removing tiles. i also have some 5mm rubber underlay left over from another apartment so one else did for me. do you know what type of adhesive i should use to glue the rubber underlay to the concrete? Re: installing advice for tiling my kitchen 4Apr 20, 2021 10:17 pm Option 3- Completely remove tiles and rubber underlay, then relay new tiles with new adhesive on the concrete floor. This will do I think. Re: installing advice for tiling my kitchen 5Apr 21, 2021 9:54 am The rubber underlay is required to reduce noise transmission via the floor. If this is removed and not reinstalled it is highly likely that the OP will be forced to rip up his floor again and install new underlay. Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6866 Ask yourself if the insurance company will be aware of the Reno. 4 7752 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8705 |
