Browse Forums Flooring & Floor Covering 1 Oct 02, 2020 1:21 pm Hi guys. I’m currently in the process of installing Hybrid floorboards through our kitchen and lounge room. Unfortunately, there is a height difference between both rooms and the lounge room needs to be raised approx: 20mm. The plan is to drop some yellow tongue StructaFlor onto the concrete slab and put the hybrid floating floorboards over the top. From what I have researched so far, I need to do the following: 1. Seal concrete slab. 2. Use a construction grade adhesive to glue the yellow tongue to the concrete. I was thinking a trowelable adhesive would work best? Am I on the right track? Can anyone recommend a moisture barrier paint and construction grade adhesive for this type of work? Thanks in advance. Jeremy Re: Yellow Tongue Structaflor help 3Oct 02, 2020 1:56 pm alexp79 you will be better off by raising the height will self levelling compound or even simple sand-cement mix Thanks mate, self levelling compound did cross my mind. The area is 6m x 6m and raising it 20mm, I thought yellow tongue would be easier and more cost effective. I will look into sand cement mix. Hi guys, I want to do some floor levelling before laying the planks and am considering doing it with self-levelling or yellow tongue PB board. I am wondering which one… 0 7491 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 13456 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6957 |
