Browse Forums Flooring & Floor Covering 1 Sep 28, 2020 10:43 am Hello Guys, This may have been posted many times, I read some posts but still couldn't get a straightforward answer. We are toggling between carpet and laminate flooring for upstairs bedrooms (rumpus and hallway would be laminate). Our main concern is noise which would be produced from laminate flooring. I got a suggestion to go with Regupol 5512 5mm rubber underlay with laminate flooring (8mm planks), which would reduce the noise considerably according to a shop's sales guy. Has anyone used this underlay before? Could you please share your experience with the noise levels using this underlay or any other suggestions for laminates. Can this laminate and underlay combo noise levels be comparable with carpets, which would be our last option to go with, where the noise DB levels would be less, I believe. Thank you. I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 6535 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8706 Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4218 |
