Browse Forums Window Furnishings 1 Feb 18, 2020 5:53 am Has anyone ever used noise cancelling curtains? We live in an area where there are some yapping dogs around the estate a couple of people who must work at night and you can hear a bit of that traffic noise. Wondering if they are worth investing in just to try and get a better nights sleep! Re: Noise cancelling curtains? 3Feb 18, 2020 10:56 am They sure do. A mate who I worked for years ago had a client that bought a new townhouse with acoustic problems. Mostly these were a result of the builder not following specs so we installed sound deadening material to common walls. There was also a busy road facing the main bedroom so they had better glazing installed in the window and then sound deadening curtains which were very effective. https://www.acousticblindsandcurtains.c ... b-EALw_wcB Stewie Re: Noise cancelling curtains? 5Sep 24, 2020 12:17 am Back in the '70's when I was working in the Board of Works, we were testing some sound deadening material, it was like a thick blanket and contained lead. We were hanging it up over a doorway, and testing the acoustic blocking properties with sound measuring equipment and a white noise generator. It was quite effective, although heavy to hang up! Maybe roller shutters outside might be a good option, apart from the obvious sound insulation in the walls and double glazing? I'm a shift worker too! Gary Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 13510 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 11865 have you used any of the motorised curtain systems available from Ebay? Which one and how is it? 0 2496 |
