Browse Forums Window Furnishings 1 Jan 27, 2017 8:42 pm I have a window door combination - 1800mm wide with the glazed door on one side making up half of that (900mm). I want to install curtains over the window/door so need to install a curtain rail and will also install a pelmet. My question is how much side overhang do I need for the curtain rail to ensure that when the curtain is open it does not interfere with the inward opening of the door. I have not ordered the curtains as yet but intend to get curtains that are pinch pleat and lined - hand opened (not corded). Thanks Bruce Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 4013 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7987 This is the best I have, as it is plastered internally now. I should add there is a steel post in the corner of the room between the window and the glass sliding door,… 3 745 |
