Browse Forums Buying Land 1 Apr 17, 2023 12:30 am Hello there, We are planning to buy a land and construct a double storey home in Adelaide. After some research we have decided to buy a 375 square meters land in a new estate near to city. We have received land contract to make 10% deposit and settlement is due early next year. up on reviewing the contract we have found easements as follows. Our block is 197 1. Red dotted line across plot 197. What does this mean? 2. We found following on sanitary drainage plan website. I can see waste water gravity main and waste water pumping running through block 197. We are confused about what are further steps from here. Do I have to worry about these? Who would be the best person to get advice from? is it conveyancer? Also, I can see a clause saying existing easement H to be extinguished. But I am not sure if they are referring to my block or something else? What would you do if you are in my shoes? Re: Advise buying a land 2Apr 17, 2023 12:32 am rocket51 Hello there, We are planning to buy a land and construct a double storey home in Adelaide. After some research we have decided to buy a 375 square meters land in a new estate near to city. We have received land contract to make 10% deposit and settlement is due early next year. up on reviewing the contract we have found easements as follows. Our block is 197 1. Red dotted line across plot 197. What does this mean? 2. We found following on sanitary drainage plan website. I can see waste water gravity main and waste water pumping running through block 197. We are confused about what are further steps from here. Do I have to worry about these? Who would be the best person to get advice from? is it conveyancer? Also, I can see a clause saying existing easement H to be extinguished. But I am not sure if they are referring to my block or something else? What would you do if you are in my shoes? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6737 I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 8199 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25306 |
