Browse Forums Buying Land Re: Engineered fill in Springfield Rise 2Jul 19, 2022 8:13 pm Yes normally piers with that depth of fill. Is it controlled fill ? Re: Engineered fill in Springfield Rise 4Jul 20, 2022 7:37 pm It will come down to the engineer whether they are happy with a rigid slab in the fill or they think piers are the best solution. That depth is getting so deep that bored piers may not be an option anyway and screw piles may be recommended. Some of the factors they will consider are, is it a double storey or single storey, is there a compaction report available, Is there going to be nature strip trees, type of fill, whats underneath the fill etc etc so best to see what the engineers recommend. What the developer says and what is reality are smetimes not the same. Re: Engineered fill in Springfield Rise 5Jul 20, 2022 8:12 pm If the fill is compacted to at least 95% (which it should as otherwise not compliant), then you could simply replace 30 cm with compacted sand (on top of geotextile), set up perimeter drainage (soil under your slab should be slightly inclining towards the drainage) and then ask your engineer to design 25 cm thick floating slab (no need to dig for footings, the whole slab is one big footing), which can be reinforced with 2 layers of SL92 mesh (as well as additional U-bar reinforcement at the edges). This is will be quite similar to German Dow slab system with the exception that Dow slabs are built on top of 10 cm of XPS for extra thermal insulation. To further reduce costs on labour, instead of deploying 2 layers of reinforcement, you can just ask your concrete supplier to mix in 10 kg/m3 of HelixSteel micro reinforcement into your concrete mix (the actual proportion would have to go through the approval of HelixSteel structural engineer though, but usually 10 kg/m3 is enough to replace 2 layers of mesh in a thick slab). In this configuration, you will certainly spend more on a concrete as well as extras on sand, soil removal and sand compaction, however, this way you will save a lot of time and labour on additional ground works, reinforcement, pods and more importantly piering, so in the end of a day, you may end with the same costs but with much more piece of mind. In comparison to standard waffle pod slab, your slab will be much better protected from any soil movement caused by the slab heaves as well as water ingress under the slab. Just my 2 cents. Re: Engineered fill in Springfield Rise 6Jul 20, 2022 8:40 pm groundzero It will come down to the engineer whether they are happy with a rigid slab in the fill or they think piers are the best solution. That depth is getting so deep that bored piers may not be an option anyway and screw piles may be recommended. Some of the factors they will consider are, is it a double storey or single storey, is there a compaction report available, Is there going to be nature strip trees, type of fill, whats underneath the fill etc etc so best to see what the engineers recommend. What the developer says and what is reality are smetimes not the same. Thanks for the information. Re: Engineered fill in Springfield Rise 7Jul 20, 2022 8:42 pm alexp79 If the fill is compacted to at least 95% (which it should as otherwise not compliant), then you could simply replace 30 cm with compacted sand (on top of geotextile), set up perimeter drainage (soil under your slab should be slightly inclining towards the drainage) and then ask your engineer to design 25 cm thick floating slab (no need to dig for footings, the whole slab is one big footing), which can be reinforced with 2 layers of SL92 mesh (as well as additional U-bar reinforcement at the edges). This is will be quite similar to German Dow slab system with the exception that Dow slabs are built on top of 10 cm of XPS for extra thermal insulation. To further reduce costs on labour, instead of deploying 2 layers of reinforcement, you can just ask your concrete supplier to mix in 10 kg/m3 of HelixSteel micro reinforcement into your concrete mix (the actual proportion would have to go through the approval of HelixSteel structural engineer though, but usually 10 kg/m3 is enough to replace 2 layers of mesh in a thick slab). In this configuration, you will certainly spend more on a concrete as well as extras on sand, soil removal and sand compaction, however, this way you will save a lot of time and labour on additional ground works, reinforcement, pods and more importantly piering, so in the end of a day, you may end with the same costs but with much more piece of mind. In comparison to standard waffle pod slab, your slab will be much better protected from any soil movement caused by the slab heaves as well as water ingress under the slab. Just my 2 cents. Thanks, this makes sense. Gives a background when talking to prospective builders. Re: Engineered fill in Springfield Rise 8Jul 20, 2022 9:23 pm alexp79 This is will be quite similar to German Dow slab system with the exception that Dow slabs are built on top of 10 cm of XPS for extra thermal insulation. I haven't heard of a German Dow slab before. Interesting option for a site with deep fill. Is there any reason why you wouldn't use XPS based pods for insulation with the Dow slab ? Re: Engineered fill in Springfield Rise 9Jul 20, 2022 11:17 pm marbles alexp79 This is will be quite similar to German Dow slab system with the exception that Dow slabs are built on top of 10 cm of XPS for extra thermal insulation. I haven't heard of a German Dow slab before. Interesting option for a site with deep fill. Is there any reason why you wouldn't use XPS based pods for insulation with the Dow slab ? They don't use pods, they use a continuous layer of 100 mm XPS sheets, which, together with 200 mm high and 50 mm thick XPS edges, forms a strong formwork for the concrete and doesn't require conventional formwork for the concrete pour. Main reason why their insulate with XPS is to prevent any potential soil expansion due to water freezing under the slab as well as to provide insulation for the in slab heating which is a default option with Dow slabs. XPS is not cheap (in Australia) but if you decide to go with heated slab or build in ACT or Tasmania, it certainly pays off. And due its poor compressive properties, you really can't use EPS under the footings. Re: Engineered fill in Springfield Rise 10Jul 21, 2022 7:06 am alexp79 If the fill is compacted to at least 95% (which it should as otherwise not compliant), then you could simply replace 30 cm with compacted sand (on top of geotextile), set up perimeter drainage (soil under your slab should be slightly inclining towards the drainage) and then ask your engineer to design 25 cm thick floating slab (no need to dig for footings, the whole slab is one big footing), which can be reinforced with 2 layers of SL92 mesh (as well as additional U-bar reinforcement at the edges). This is will be quite similar to German Dow slab system with the exception that Dow slabs are built on top of 10 cm of XPS for extra thermal insulation. To further reduce costs on labour, instead of deploying 2 layers of reinforcement, you can just ask your concrete supplier to mix in 10 kg/m3 of HelixSteel micro reinforcement into your concrete mix (the actual proportion would have to go through the approval of HelixSteel structural engineer though, but usually 10 kg/m3 is enough to replace 2 layers of mesh in a thick slab). In this configuration, you will certainly spend more on a concrete as well as extras on sand, soil removal and sand compaction, however, this way you will save a lot of time and labour on additional ground works, reinforcement, pods and more importantly piering, so in the end of a day, you may end with the same costs but with much more piece of mind. In comparison to standard waffle pod slab, your slab will be much better protected from any soil movement caused by the slab heaves as well as water ingress under the slab. Just my 2 cents. And a nature strip tree ? Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16028 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6210 2 4380 |
