Browse Forums Buying Land 1 Sep 21, 2020 1:30 am Hello, I have been looking at buying land and I am not sure how to find out the fall on the land. I can't see any survey map in section 32. I'm mostly looking at private sale of land on new estates. Is it possible to obtain a land survey copy from the developer? Is there any way of finding out if the land has any fill? Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25514 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 2657 Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 5143 |
