Browse Forums Buying Land 1 Feb 05, 2022 9:30 pm Hi, a noob question here to which I think I know the answer but need someone to confirm. I’m buying this lot 50. The developers are doing the sandstone retaining walls around the perimeter of the block. In the attached photo the honeycomb area is the building exclusion zone. My question for you all is how much is the slope on that honeycomb area starting from my neighbouring lot I.e want to know the slop from the neighbours retaining wall on the right to where my building pad (area outside the honeycombs) starts? Thanks for your help. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Land deposit: 17 Nov 16 Build contract: 17 Apr 17 Land settled: 16 June 17 BA: 23 June Slab: 3 Aug Frame: 21 Aug Enclosed: 10 Oct Fixing: 6 Nov PCI: 14 Dec Settlement: 21 Dec 17 https://forum.homeone.com.au/viewtopic.php?f=31&t=88597 https://forum.homeone.com.au/viewtopic.php?f=31&t=88597 Re: Help with understanding slope 3Mar 11, 2022 5:01 pm From what I can see on the contours you can calculate the fall. The top contour is 430 and subtract the lowest value at the bottom of the block to get the fall in metres. As I understand it the contour markings are the height above sea level. Cheers, DM Re: Help with understanding slope 4Mar 11, 2022 5:07 pm If I read your plan correctly you have a 3 metre drop from the top to the bottom of your block. You know the distancve from the top to the bottom and should be able to calculate the fall as per this: DEGREES OF SLOPE TO FALL CALCULATOR – Including Gradient – coherence.com.au Cheers, DM ask the surveyor for clarification would be the logical approach 1 20712 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 226215 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25558 |
