Browse Forums Buying Land Re: NBN pit & pipe 10Oct 09, 2018 1:10 pm Hi guys, I work for a builder in Perth and we come across this often and it is absolutely ridiculous that it isn't a condition from the WA Planning Commission, I have tried several times to raise it with them but seem to get fobbed off, I have recently contacted the Planning minister and of yet haven't received a response but am going to follow up. The developer of these blocks think its a builders responsibility for this and as previously posted is is most definitely not but we seem to get the blame for it most of the time, if the buyer of the land hasn't written up the offer when they come to us we tell them to write the following clause as a special condition. "Communications infrastructure to be completed by developer as per the federal government communications act." Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10866 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 5633 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3661 |
