Browse Forums Pools & Spas 1 Apr 11, 2020 8:38 pm Re: Help required re hole in spa pvc piping. 2Apr 12, 2020 9:54 am It would either be for a temperature sensor ,a broken t peace or a Venturi . Follow the pipe . Where does it go from and to ? Cheers Re: Help required re hole in spa pvc piping. 3Apr 12, 2020 10:19 am wheeliworks It would either be for a temperature sensor ,a broken t peace or a Venturi . Follow the pipe . Where does it go from and to ? Cheers Hi mate Thanks for your feedback. Ok so that pipe runs if to the left to the spa proper. Its definitely the main pipe. To the right it runs through that large valve which we turn prior to operating same. Turning 90 degrees opens the valve and conversely turning anti clockwise shuts off the valve. That pipe then runs to the central canister. For mine it looks like it is missing a pvc coupling or a piece that snaps into that area. Hope this helps. Re: Help required re hole in spa pvc piping. 5Jun 15, 2020 7:52 pm You may use a drill to make a new hole and plastic glue to fix your first hole. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 5642 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 2957 The coupling, which is made from flexible PVC, needs to comply with AS/NZS 4327 which specifies the requirements for metal banded flexible couplings used in low-pressure… 1 2228 |
