Browse Forums Pools & Spas 1 Sep 18, 2019 12:38 am Hi, I'm building a concrete pool that will be finished with https://www.blueglasspebble.com.au/glass-pebble-products.html. I did not include any waterline tiles in the contract but the more I read about them the more I think I should add them. It looks like the pool will look better and it will be easier to maintain. I asked my builder to quote the work and that will add around 5-6k for a 4x8 pool. Are they really a must-have? Can you add them later? Thoughts? Re: Are waterline tiles a must have? 2Oct 03, 2019 2:25 pm Hey, Waterline tiles are going to help with the scum line, as it'll be easier to brush and they make your pool look nice. Can you add them later... yes, but its a lot of work and no way will it be as good as, if you have them laid before the pebbling. 1st you'd have to drain the pool, then with a steady hand, you'd have to remove the pebble 300mm (and a bit down) remove the pebble which has bonded to the coping... and you'd someone with a super steady hand to cut straight around the perimeter, without damaging the pebble. Can it be done? yes, would it be worth it, imo.. not really. plus Refilling of the pool, maybe acid washing the mess they've made whilst doing the tiles, adding chemicals, balancing The cost to add them later would be extra $1000's you might as well have them on to begin with. Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 41402 Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand… 8 24597 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18714 |
