Browse Forums Pools & Spas 1 Dec 06, 2016 9:06 pm Hi All, Just wondering if anyone knows what the recommended distance is between a new home and an in-ground fibreglass pool? I think we need to be about 1m off the boundary but hoping someone might have an experience they could share. Our site width is 4.8m from house to boundary so looking for a long skinny pool if it will fit... - otherwise known as Kym - Re: Distance between pool, house and boundary 2Dec 06, 2016 9:22 pm The distance from house depends on the depth of footings or piers And depth of pool . If planned in advance you can be as close as 200mm away . If not you either need to consult a engineer or work with standard zoi"s . . As for rear boundary fence 1m if you are doing a complying development or much closer if submitting a da. Re: Distance between pool, house and boundary 3Dec 15, 2016 8:33 am It is usually the depth of the pool is the distnce from any structure; i.e 1.8m deep, 1.8m from structure. I have a pool off the back of my house and also had to get piers even being 1.5 from the house. Re: Distance between pool, house and boundary 4Feb 05, 2017 12:02 pm I am a little bit worrying about my neighbours who put their pool quite close to the boundary. 80cm to the to-be water line. Blacktown council (NSW). Is it legal? Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Distance between pool, house and boundary 5Feb 05, 2017 1:56 pm If they have less an 1m to waterline it would of needed a development application . You would have been notified . If it was complying development you wouldn't be notified .notified but pool needs to be 1m off boundary. Re: Distance between pool, house and boundary 6Feb 05, 2017 1:59 pm ![]() If they have less an 1m to waterline it would of needed a development application . You would have been notified . If it was complying development you wouldn't be notified .notified but pool needs to be 1m off boundary. The strange thing is that we haven't been notified, at all. Thank you. This is very interesting. Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Distance between pool, house and boundary 7Feb 05, 2017 2:13 pm If it is still being built they will have a sign out the front of their house with builder and certifier details . You should ring the certifier . If it is complete you can ring the council' Re: Distance between pool, house and boundary 8Mar 12, 2017 6:20 am ![]() I am a little bit worrying about my neighbours who put their pool quite close to the boundary. 80cm to the to-be water line. Blacktown council (NSW). Is it legal? I'll take a guess here. If you are able to measure that it's 80cm, then they might be allowing 15-20cm concrete wall and tiling. It's only a guess Good luck Good on you for having a go I am the opposite of DIY (so will pay a builder) - our vibe is industrial/simple so current thinking is 150mm concrete and then internally is… 3 3492 Found the answer. The recommended distance is .... 1 6436 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 18078 ![]() |
