Browse Forums Pools & Spas 1 Jun 21, 2016 8:01 pm We are planning to build a new house in Melbourne next year, and hoping to add a pool down the track. The backyard is relatively small with easement at the back, so I sadly decided not to go with Inground lap pool idea. It can get as close as 1.5 m to the building and might be quite overwhelming for the limited space. I'm also just not keen with the unknown at this point as builder put a lot of clauses I regards of building the pool close to the house. So thinking of smaller size pool, hopefully above ground type, or semi Inground with decking all around. I don't like the look of traditional above ground pool (one with scalloping) so thinking about either Above ground fibreglass - Miami pool Nicole Or This above ground liner, but with treated log as structure http://www.paradisepools.com.au/brightw ... round-pool Wondering if anyone have experience/ feedback on either? Thinking about adding this swimming machine down the trac as well http://www.fastlanepools.com.au/fastlane.php Re: Above ground pool with log structure 2Jun 21, 2016 10:01 pm If you haven't built yet you can have the builder put some piers down to the depth of a future I ground pool then you can build against the house at a future date . Is your easement sewer main & storm water run off . If it is sewer have you checked zoi regulations . Usually you can get from 600mm-1m away if deep end is near pipe . Feel free to pm me for details Cheers Re: Above ground pool with log structure 3Jun 22, 2016 7:59 am wheeliworks If you haven't built yet you can have the builder put some piers down to the depth of a future I ground pool then you can build against the house at a future date . Is your easement sewer main & storm water run off . If it is sewer have you checked zoi regulations . Usually you can get from 600mm-1m away if deep end is near pipe . Feel free to pm me for details Cheers It is a sewer @wheeliework The reason for not placing it against the house is that any future work relating to the pool that affect the house will void the warranty. They want to put a dropped footing as piers are not sufficient (we have up to 700mm fill and was budgeted for 1.3m fill, so they'll pier the house regardless) Placement wise it would be awkward too as we have full size windows at the back. This is the initial idea, but hubby does not want to open the back window and have a pool fence right after (me neither). We have dogs and would keep a good size back yard. Sewer easement at the back - 2m and supposedly 1.2-1.3m deep. I thought i can adjust to have smaller slim above/semi above ground pool on alfresco side, as close as possible to the fence and the easement. Side garden is 3.3m and back is 6.4m including easement Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Send from my phone through Tapatalk. Pardon the incorrect autocorrect and fat fingers. my blog: http://sttropez27build.blogspot.com.au Re: Above ground pool with log structure 4Jun 22, 2016 8:14 pm Here is a very similar house layout with a sewer close . You can see on the drawing the zoi angles .I'm presuming being bedrooms it's only windows not doors opening to back yard . If you have a large footing you would at worst be able to have bottom of the pool at the same depth as bottom of the footing . Is the sewer 1.3 below current ground level or 2m deep after filling . You can easily get your own engineer to assess for you . Having a out of ground pool will make the zoi on the sewer worse as it is taken on a 45deg angle to bottom of pool shell . Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Above ground pool with log structure 5Jun 24, 2016 12:04 pm wheeliworks Here is a very similar house layout with a sewer close . You can see on the drawing the zoi angles .I'm presuming being bedrooms it's only windows not doors opening to back yard . If you have a large footing you would at worst be able to have bottom of the pool at the same depth as bottom of the footing . Is the sewer 1.3 below current ground level or 2m deep after filling . You can easily get your own engineer to assess for you . Having a out of ground pool will make the zoi on the sewer worse as it is taken on a 45deg angle to bottom of pool shell . Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thank you! I guess at this point I will see how it goes. All windows are full size sliding door at the back, so being too close to the house is not ideal Send from my phone through Tapatalk. Pardon the incorrect autocorrect and fat fingers. my blog: http://sttropez27build.blogspot.com.au Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11753 There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 6682 8 4166 |
