Browse Forums Pools & Spas Re: Should we try and lift a fiberglas pool out of level? 23Jun 14, 2016 5:17 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Should we try and lift a fiberglas pool out of level? 26Jul 08, 2016 11:52 am Franky40 Hi all, Just as a matter of interest, what is engineer's recommendation how to return pool levels back to tolerances? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Thanks for the informative response! I'll feed that back to the site supervisor. 2 4130 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6595 |
