We've got a ceramic FB pool.
The only issue is when we get rain - too much. It can overflow.
We could have had an auto outlet but didn't go with it ...
Any ideas on solutions now ?
Browse Forums Pools & Spas 1 May 03, 2015 11:23 am We've got a ceramic FB pool. The only issue is when we get rain - too much. It can overflow. We could have had an auto outlet but didn't go with it ... Any ideas on solutions now ? Re: Fibre Glass Pools - Auto Outlet - Ideas ? 2May 03, 2015 11:23 am Saint Mike We've got a ceramic FB pool. The only issue is when we get rain - too much. It can overflow. We could have had an auto outlet but didn't go with it ... Any ideas on solutions now ? I don't want to drill through the shell ... Re: Fibre Glass Pools - Auto Outlet - Ideas ? 3May 03, 2015 8:04 pm Fit a 3 way valve between pump & filter & run it to a sewer point . To drain turn on pump & turn valve . . You can reduce pipe to 25mm to make routing it easier Re: Fibre Glass Pools - Auto Outlet - Ideas ? 4May 04, 2015 2:00 pm wheeliworks Fit a 3 way valve between pump & filter & run it to a sewer point . To drain turn on pump & turn valve . . You can reduce pipe to 25mm to make routing it easier Thanks Wheelie - got something like this - but I need to be there to do this. I looking for something that could work without me there. Re: Fibre Glass Pools - Auto Outlet - Ideas ? 5May 04, 2015 7:24 pm The problem with auto overflow is when using the pool & splashing you will loose water. Then top up , extra salt. & work balancing water .. Unless you have a unused fitting in the pool you know you would need to dig & drill. Cheers Re: Fibre Glass Pools - Auto Outlet - Ideas ? 6May 05, 2015 6:26 pm wheeliworks The problem with auto overflow is when using the pool & splashing you will loose water. Then top up , extra salt. & work balancing water .. Unless you have a unused fitting in the pool you know you would need to dig & drill. Cheers Yes - was thinking of a plastic conduit - from the back of the cleaner box - top - to the outside. Would allow run out as needed ? What do you think ? Re: Fibre Glass Pools - Auto Outlet - Ideas ? 7May 06, 2015 9:46 pm Your skimmer would normally be set in concrete. As would be the overflow socket at rear of it . To work as a overflow to pipe needs to run downhill . This would usually mean cutting concrete & paving . Expensive exercise. Re: Fibre Glass Pools - Auto Outlet - Ideas ? 8May 07, 2015 9:04 am wheeliworks Your skimmer would normally be set in concrete. As would be the overflow socket at rear of it . To work as a overflow to pipe needs to run downhill . This would usually mean cutting concrete & paving . Expensive exercise. I thought you could bore through from the outside - I have a slope at back - but a pipe through to allow water to flow through as it reached the top of the box. Nothing fancy. But - would need to be waterproofed etc. Just allow gravity to work. As water got to that level - it would flow out via pipe. Re: Fibre Glass Pools - Auto Outlet - Ideas ? 9May 09, 2015 8:30 am That would work . Just hope there is no reo in the concrete behind skimmer. If you have photos of Formwork before concrete was done it will help. Cheers Re: Fibre Glass Pools - Auto Outlet - Ideas ? 10May 09, 2015 11:22 am wheeliworks That would work . Just hope there is no reo in the concrete behind skimmer. If you have photos of Formwork before concrete was done it will help. Cheers Yes - smart thought - I think I do have pics - will hunt about. From memory the side was done very quickly - ie it is quite narrow - so odds are no reo. The deck part used reo - but much larger. It was poured from truck pretty quickly - into form work. Then coping. I rendered outside with the stuff you buy from Bunnings - looks good. Seems to be the way to go. Its about 40-50+ cms wide on the box side - but "pipe" would only have to be about half/quarter (or less) of that - from edge to outside box. Re: Fibre Glass Pools - Auto Outlet - Ideas ? 11Jun 18, 2015 10:26 am Overflow pipe installed. Looks OK. Will now have to wait for rain and see ... Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7717 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3851 |
