Browse Forums Pools & Spas 1 Jul 01, 2012 8:37 am Hi all We are new to pools and we have an in ground concrete pool with a quartzon service and at the moment the water level seems to be going down really fast. Around a good 2 inches (Maybe a little more) in the last couple of weeks. It seems to be going down a lot more in the winter than it did in the summer when everyone was using it. Is that normal? Would it be worth doing the bucket test I've read about in other posts to see if there is a leak or is it just normal for winter for the water level to go down quickly? Thanks for the advice!! isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18318 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6999 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47609 |
