Browse Forums Pools & Spas 1 Dec 26, 2022 2:12 pm Hi folks, Looking for some guidance before I talk to the pool company. My concrete pool is yet to be rendered, so still at the raw concrete stage. There has been a lot of rain over the last few months so the pool had filled considerably. As the water was quite filthy over time, I invested in a submersible pump and got rid of most of the water about two days ago. Most of the water drained off into the garden and drain, but a lot also drained off around the pools outer edge. Given the heat we are experiencing I thought it would water the garden a bit too. However, I noticed yesterday a small water stain that was nowhere near the remaining waterline. Today the water stain appears to be larger and looks like it is leaking from the outside in. Will this be an issue after the pool is rendered and filled? What should the pool company do to fix this? Thank you for any help too! DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24467 My first suspect area is at the bottom of the harvested downpipe furthest from the tank. PVC downpipes expand and contract with heat and cold, putting pressure on the… 3 1470 |
