Browse Forums Pools & Spas 1 Oct 17, 2022 1:33 pm Hi, Can anyone tell me what these are in my pool please? I asked my local pool shop and they said that a lack of calcium in the pool results in it being pulled out of the grout between the tiles, creating holes. The white nodules inside the holes are hardened calcium. I'm supposed to brush to try and clear the nodules away. When I took a second look, I noticed that the pattern of these holes/nodules is perfectly regular, in the same places around every tile, so now I'm questioning how that could be. I don't think I have much of a chance of dislodging those things, and they are everywhere. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: White nodules in between pool tiles 3Oct 17, 2022 3:11 pm aussieta they look like tile spacers your water has been too acidic and has dissolved the grout out id assume these would be sheet mosaic, not individual tiles. Could be the backing, but im 100% with you on grout being erroded. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 2373 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 10890 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 9947 |
