Browse Forums Pools & Spas Re: Stormwater pipes where I want to build pool 2Oct 10, 2021 12:16 am Vicki63 What can I do if storm water pipes in the way for a pool to built From recent pool quote conversations, I think not much you can do. Move location of pool, change shape so to avoid pipe work? 4 5313 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5952 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11182 |
