Browse Forums Pools & Spas 1 Oct 08, 2020 4:10 pm Hi all New member with a pool leak issue hoping someone has some advice. Vinyl liner, concrete in ground pool, a bit old. Definitely leaking and we’re considering getting it re-lined. Not cheap! Pretty sure there are some leak issues from the liner but I’d like to make sure it isn’t the plumbing first. So, pipes are empty when I turn the filter on. Is this an indicator of a plumbing issue? Re: Pool leaks 2Oct 10, 2020 7:01 am Andyman3000 So, pipes are empty when I turn the filter on. Is this an indicator of a plumbing issue? Does the pool leak more when the pump is running? The leak may be in your pipework not the pool There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2592 If the build keeps returning, thats a plus!! but it would also suggest he doesnt know what his looking for, an independent inspector should have fresh eyes on the issue. Good luck 1 1976 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12672 |
