Browse Forums Laundry Appliances Re: Washing machine space 2Oct 03, 2016 6:18 pm Its going to be very tight, and probably you will have an issue with skirting boards making it too narrow. The distance marked on the plans is between the framing, you need to allow for plaster, and skirting boards, which will most likely put you into can't fit territory. Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 18010 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10692 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3886 |
