Browse Forums Laundry Appliances 1 Mar 11, 2011 6:20 pm Not sure if this is the right forum - but worth a shot! Can anyone advise on how to troubleshoot fixing a leaking washing machine? Our hot water tap leaks - if the tap is not turned off after the initial fill the tub will leak from underneath. I've opened up the lid mid-wash and can see the stream of water still trickling out from near the soap dispenser. I've checked the washers in the end of the hose that connects to the machine and they appear to be fine -(looks identical to the cold water washer that doesn't leak). Can anyone offer any further suggestions? Re: Leaking Washing Machine 2Mar 11, 2011 7:44 pm Sounds like the hot water solonoid valve in the machine is leaking. As you don't seem familair with the working of washing machines it could be time to call the repairman. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Leaking Washing Machine 3Mar 11, 2011 7:45 pm Hi, Your hot water inlet solenoid valve has failed. This is an electrically operated valve at the back of the machine which shuts off the water when the right level is reached. There is also one of these on the cold water inlet. They are not expensive to buy at the spare parts counter, but if you are not sure, call a serviceman as there are 240V connections there. The machine should not have to be taken away, as it is a simple job on most. You might consider having the cold water valve replaced at the same time just for peace of mind. Cheers Re: Leaking Washing Machine 4Mar 12, 2011 1:48 am I just had mine fixed (old Kleenmaid/Speedqueen commercial washer). To buy the part would have been around $100. To have someone come and supply & install was $210 or so. Definitely worth getting the tradesman to do it. Judie Re: Leaking Washing Machine 5Dec 01, 2011 8:38 pm The first thing to do is identify where the leak is coming from. While a machine can escape from a number of places, most of the few places are the same. The location of the leak If the leak was large, it is usually easy to find the source comes from what would normally be able to see a trace of water and soap. Whether the leak is small, place newspaper underneath the washer. Check after each wash for any signs of leakage. Once you find the area of ββthe leak, make sure there is anything above that is leaking and dripping down. The easiest way is to start from the wet and the initial feeling up and around there on a trail. If the leak is water and soap may be able to see white stripes still dry soaps from the leak. Escape the door seal The door seal stops water flowing through the hole in clothes that are put in once the door is closed. General wear or objects left on clothing can create tears in the seal. This type of leakage is typically run in the back of the front panel and displayed on the floor. In general, these holes you can find by clicking on the seal to expand it and visually inspect. If so, you will need to replace the seal. See here for more details. The leak can also run down the front of the panel, but in this case, first check that there is nothing obstructing the seal. This could be a loose thread or soap residue. Try cleaning the glass and gasket with a damp cloth. This could restore the label and avoid having to replace it. Leaking from the soap box The soap box, where you put the soap powder and air, has no seal and is based on an incline and gravity to prevent leakage. This can start to lose a couple of situations. One is a blockage, usually caused by putting too much dust in the box which means it does not dissolve and instead gungy form a dough. This builds up over time restricting the rate at which water can escape. Once this is less than the speed is fulling, overflow exceeding the front. The answer to this is simply to remove the blockage. First manually remove any excess powder that is visible, closed the washer, pour boiling water into the soap drawer. Repeat this procedure until the water comes off easily, then put the washer on a quick wash to clean the system. The second reason for this when the water pressure is too high. If you have a tap on the pipes that connect the hoses, you can try to make this means of reducing the pressure. Leaking from drain pipe Sometimes the blockage occurs at the drain. This is the tube which pumps the water used at the end of the cycle in the drain outside. These usually have a sump in the bottom before exiting. If the crash occurs here, the water will back up the pipe in place and overflow on the floor. In this case, the trap must be removed and cleaned the block. Drain the pump Make sure that the leak comes from the pump and not one of the hallmarks of connecting the pump. If the pump is leaking, it is much easier and much less economical to replace the entire pump, rather than try and close it. This is a relatively easy process, with the participation of disconnecting and reconnecting the electricity and block the inlet and outlet. Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 18014 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25065 My first suspect area is at the bottom of the harvested downpipe furthest from the tank. PVC downpipes expand and contract with heat and cold, putting pressure on the… 3 2423 |
