Browse Forums Laundry 1 Aug 16, 2011 10:03 am Could someone please tell me if the laundry sink below is with bypass or without? Laundry sinks - bypass or without 2Aug 16, 2011 10:48 am Your washing machine drain hose has been connected up to the PVC drain pipe underneath your sink directly, so I guess it has been bypassed. Although, some sinks/troughs have a drain hole/s either side of the sink at back corners for washing machine drain hose to be poked into. Those holes must then be connected up to the PVC pipe below with a bypass kit which would come with the sink. I see no evidence of this with yours. Hope this helps. Building NBG Buckingham 320E Eastern Suburbs Melbourne Knockdown & rebuild Build startup 28th October 2010 http://buckingham320e-the4ofus.blogspot.com/ Re: Laundry sinks - bypass or without 3Aug 16, 2011 10:58 am Thanks portas I would like my washing machine hose to be connected to the sink "from underneath", if you know what I mean... because I am having a benchtop above the washing machine etc. So I definitely need to order a sink WITH bypass, right? This is not my laundry, by the way. Laundry sinks - bypass or without 4Aug 16, 2011 11:16 am I believe you only need to order a sink with bypass kit when the hose is poked into hole in sink at the top. As long as the plumber connects a PVC pipe like yours to the sink underneath, then you can connect up the hose to that under the sink. I would ask the plumbing supplier to confirm this before you order, just to be safe. Cheers Building NBG Buckingham 320E Eastern Suburbs Melbourne Knockdown & rebuild Build startup 28th October 2010 http://buckingham320e-the4ofus.blogspot.com/ Re: Laundry sinks - bypass or without 5Aug 16, 2011 11:26 am If it is a sink with bypass, it will have a hole in one or both back corners of the top of the sink lip. You can then insert the waste hose from a washing machine into this hole. The hole(s) are then plumbed to the waste under the sink.
It sounds like you want a sink without bypass (ie no holes on the top of the sink lip). The photo you posted shows a sink without bypass connected. This is an example of a sink with bypass (not my sink either ) Hope that helps! Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 21388 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 21237 Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier… 0 5484 |
