Browse Forums Laundry 1 Jan 25, 2022 5:34 am Any thoughts on building with ausmar?????we are in the process of finalizing housefloor plan with them. Our block is very restrictive,, narrow and short. We managed to squeeze in 4th bedroom by converting it to study and laundry inside garage. We are not able to put any aide access in the garage to hang clothes!!!!! Due to being zero boundary and we maximizes it. So we are putting it inside walk in pantry thats is 1.5m x 1.5m in size, this would mean l will loose shelvings on the side. any suggestion where we can put side acces door to hang clothes.wouldnt want to use alfresco access to hang clothes. I have attached foto of houseplan. Any suggestion pleaseeeeee Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Side access to hang clothes 2Jan 25, 2022 10:21 am Seems impossible. You have all sides of your house blocked. One idea you could bring to your designer and see if they can re structure the house. Swap locations of master Bed1+Ensuite with Bed3+Bath. Put Bed2 and Bed3 at the back end of the house with Bath and possible laundry. This way your laundry won't be in the garage, and your laundry can possibly open to your back yard. Hope your professional designer can make this happen. Re: Side access to hang clothes 3Jan 28, 2022 9:53 am not in the pantry ... consider a dryer and fold up rack in the garage and an extra fold up rack on the outside of the ens wall and what is the purpose of the external wall in the pantry and can you post a site plan showing the setbacks all around and the correct dimensions shown on the plan...it looks like it might have been partly mirror reversed and the numbers don't read accurately Hi, Building a new place and I have limited space from garage to fence. 3130mm width, then opens up over 5000mm once I pass tmy garage. I need a fence that goes from… 0 3442 DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 2437 |
