Browse Forums Building A New House Re: Building with Visionone in Aveley - More Nearmap Updates 481Jul 04, 2015 12:43 am Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Building with Visionone in Aveley - More Nearmap Updates 483Jul 04, 2015 11:45 am Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Building with Visionone in Aveley - More Nearmap Updates 484Jul 04, 2015 7:12 pm Our Rivello build in Ellenbrook Re: Building with Visionone in Aveley - More Nearmap Updates 485Jul 04, 2015 11:58 pm Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Building with Visionone in Aveley - More Nearmap Updates 486Jul 05, 2015 8:53 am Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: Building with Visionone in Aveley - More Nearmap Updates 488Jul 06, 2015 1:01 pm clintdb Internal dimensions are normally given as the distance between the structure (not allowing for wall finishes). On a timber frame, that is the dimension between the frames and the plasterboard lining then reduces that dimension by around 20-25mm total. It might be the same thing for yours, where the dimension is brick-to-brick and the render reduces this. Cabinet makers will typically do a site measure once everything is in place and construct accordingly as there can be many little variances for whatever reason. Thanks clintdb, I think this would be the case for our build too. MalSannie Love the nearmap images, Hootie, wish we'd done that! I couldn't find the property search but I'll look again when it isn't almost midnight Cheers MalSannie, the property search link is: http://au.nearmap.com/property-reports. Just enter your street address in the search box and it should display the latest nearmap update of your property. Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Building with Visionone in Aveley - More Nearmap Updates 491Jul 06, 2015 8:29 pm Althom If you are in WA you can download WA Locate from Landgate. This is free and is basically NearMap for the Perth area loaded on top of Google Earth Hey Althom, thanks for this tip, I will check out WA Locate! Althom Normal to see some light seeping through under the ridge capping on a colourbond roof I am hoping so and can also understand what the other have posted in another thread on the topic I posted [url=started a thread in another section]here[/url]. The SS has been contacted about the light thru the roofing and he will check the items we listed for us. Today my wife spotted someone making notes on the wall, so in effect the "writing's on the wall"!! Which apparently means the start of ceilings? We hope. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I think this shows that whoever did this must be really on the ball lol...: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hopefully we shall see ceilings start tomorrow Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Building with Visionone in Aveley - Ceilings soon? 492Jul 06, 2015 9:58 pm love the nearmap vision of your home Hootie I have been watching your progress for a while now it's great seeing it steaming along Re: Building with Visionone in Aveley - More roof issues... 493Jul 07, 2015 8:36 pm Petad love the nearmap vision of your home Hootie I have been watching your progress for a while now it's great seeing it steaming along Cheers Petad, we are happy that it is moving along now, just a few niggles here and there, but ur SS is always pretty responsive in sorting them out. We took the chance to go to the house today after the heavy rains to see if there would be anything in regards to the roofing that we would need to be aware of and this is what we found: 1) Roofing needs tidy up in some areas: The first photo is viewing from the front of the house. The pitched roof joins to a flat room behind the pier and we seem to feel that the install needs to be cleaner? http://i1274.photobucket.com/albums/y437/Hootie1/Misc/Screen%20Shot%202015-07-07%20at%206.14.26%20pm_zpse3jpwuu4.png Issues we spotted - a) Top circle - flashing install need to be neater? b) Middle circle - There is a huge gap between where the corrugated roof sheets ends and the flat roof sheet... c) 2nd circle from bottom - Roof sheet edge needs to be secured? d) Bottom circle - Gutter dented.... 2) Leak in garage ceiling: The gap in the roof sheet in b) could have led to water leaking into the garage ceiling board? http://i1274.photobucket.com/albums/y437/Hootie1/Misc/Screen%20Shot%202015-07-07%20at%206.14.37%20pm_zpsifm9agpx.png 3) Is this normal method of ridge capping? Then there is this...is it normal to have the ridge capping screwed onto the corrugated sheet in this manner?: http://i1274.photobucket.com/albums/y437/Hootie1/Misc/Screen%20Shot%202015-07-07%20at%206.14.11%20pm_zpsylt61olk.png 4) More leaks? This was spotted between bedrooms 2 and 3. Logically, our thinking is that with the downpipes in place, fresh leaks like these should not occur? http://i1274.photobucket.com/albums/y437/Hootie1/Misc/Screen%20Shot%202015-07-07%20at%206.14.46%20pm_zps4yk6l8x2.png We will highlight these points to the SS at our next opportunity. On the bright side.....we have some work done on the upcoming bulkheads and gyprock has been delivered! Which means ceilings should start soon! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Can't wait to have ceilings up! Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Building with Visionone in Aveley - Ceiling started! 494Jul 08, 2015 12:06 pm Hi Hootie I would want it perfect I really would not like rain coming in it would be more than annoying. I was always taught if a jobs worth doing do it right the first time.... sounds easy enough I also noticed on your time frame we signed our PPA at the same time Re: Building with Visionone in Aveley - We have ceilings! Pi 495Jul 08, 2015 8:54 pm Petad Hi Hootie I would want it perfect I really would not like rain coming in it would be more than annoying. I was always taught if a jobs worth doing do it right the first time.... sounds easy enough I also noticed on your time frame we signed our PPA at the same time Hey Petad, can't believe how time flies! It seems faster sometimes when one is building. Already July and we started the process purchasing the land only one year ago...and now we have most of the house sitting on it! Positive thing is that our SS has been super responsive in our queries about the roof issues. He has seen the photos that I've emailed to him and he will get on it asap. The H1 forum people have also been invaluable in giving their opinions and comments about the issue. Today we have most of the ceilings done! The tradies will be coming back tomorrow to complete some ceilings and install the remaining cornices. What a difference having ceilings make! So happy to see the progress today! Master Bedroom: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Verandah outside Master: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Living/Kitchen area (kitchen bulkhead): Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Theater with raking ceiling and bulkhead for a/c: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Another view of Theater: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Raking ceiling at main entry: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The guys were still working past sunset and are from China...was funny that several short conversations we had with them were naturally in Mandarin, but we left them to finish up as they seemed very focus on the job... Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Building with Visionone in Aveley - We have ceilings! Pi 496Jul 08, 2015 9:27 pm Amazing progress Hootie, looks like lots has happened this week! Re: Building with Visionone in Aveley - We have ceilings! Pi 497Jul 08, 2015 9:39 pm Wow how good does it look amazing Re: Building with Visionone in Aveley - We have ceilings! Pi 498Jul 08, 2015 9:51 pm Wow! Things are moving right along, in a way it's a blessing for you to get the rain so these little things can be picked up now rather than later My topic thread: viewtopic.php?f=31&t=76249&start=20#p1316378 Re: Building with Visionone in Aveley - We have ceilings! Pi 499Jul 08, 2015 10:56 pm They are flying along Hootie, now that you have the roof, you don't have to worry about the rain slowing things down. Glad your SS is quick to respond, I am sure the issues will be sorted out soon. Our building journey viewtopic.php?f=31&t=77582 Re: Building with Visionone in Aveley - We have ceilings! Pi 500Jul 08, 2015 11:49 pm You're steaming ahead, hootie! It's great that your ss is onto the roof issues, definitely one thing you don't want unaddressed. Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10229 That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81896 I would be wary. Is you site demilished but nothing else done? Sounds like liquidity problems to me. Our builder did the same. Got hundreds of thousands of dollars of… 2 15413 |
