Browse Forums Kitchen Appliances Re: Gas Cooktops 2Oct 24, 2020 10:30 am Personally, I'd get an induction cooktop. • Sensitive temperature control. • Fast reaction time, like gas. • Far easier to clean than gas. Actually, if ditch the gas connection to the home altogether! Building an all-electric home. Foregoing gas should not only reduce building costs, it'll also result in no gas daily service charges, saving over $300 a year in most cases. Use reverse cycle AC to heat the home, cheaper to operate than gas. Hot water heat pump to heat water, again cheaper to operate than gas. Induction cooking. All powered by a good sized solar PV system. If you're on Facebook & interested in this approach, join the My Efficient Electric Home (MEEH) group. I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20640 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 4010 We are about to partially demo our house to begin a major renovation… by partial it almost may as well be a new build (keeping front for heritage) This will require the… 0 4982 |
