Browse Forums Interior Decorating Lounge 1 May 30, 2020 10:23 pm Suggestions on what to put on the wall under the pendant. Im getting a slimline console for along the hallway and some artwork or mirror. But I feel like I need something under the pendant because it is the focal point when entering the house. And do you think the pendant works there or should I replace it with something not so far down? Would love to know your thoughts. Thank you!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 52016 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61687 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8873 |
