Browse Forums Interior Decorating Lounge 1 Aug 24, 2015 10:20 am Hi!! We bought our house 2 years ago and have happily decorated every room in the house except our lounge room. The shape of the room is a nightmare and all the windows makes it a tad limited, I desperately need some advice/ ideas on where to put our furniture. We are thinking of mounting the TV - but to what wall? I would also love to put in an electric fireplace and mantel. There is also a corner nook that I'm not sure what to do with, our dining area is in another room so this is all vacant space. Were thinking of mounting the tv to the entry divider wall with the fireplace below, but not sure where the foxtel box/ dvd player etc would go. Not all our furniture needs a spot as i'm happy to get rid of pieces for better suited items. I hope I've correctly attached the photos and a floor plan. Please help! Thank you Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Desperate advice - furniture layout in odd shaped lounge 2Aug 27, 2015 6:41 am Wow....that room is a challenge due to its shape. I'll try to help in the next couple of days.....I'm thinking your TV needs to be moved. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Desperate advice - furniture layout in odd shaped lounge 3Aug 27, 2015 10:24 am Hi Michelle, Yeah I have spent a lot of brain power on this room, I'm hoping it's a simple solution that I've missed. Happy to move the TV and get an electrician in relocate points. Just want the room to be utilised the best way with minimal dead space. I would really appreciate any input, thank you!!!! Re: Desperate advice - furniture layout in odd shaped lounge 4Aug 27, 2015 8:23 pm Children yet or in the future plans?? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Desperate advice - furniture layout in odd shaped lounge 6Aug 28, 2015 12:40 pm Hi Michelle - hopefully children soon. Ive thought about a kids play area in the small nook (listed as dining area). Hi Ari - we aren't sure if it's load bearing, but that was one of the thoughts we had. We do like that there is the separation at the entry, but it makes the shape of the lounge room quite difficult to decorate. What kind of new entry wall would you recommend? My hubby likes the idea of mounting the TV to the back of it. Also mindful that the entry is tiled and the lounge is freshly carpeted so there is already a set division. Re: Desperate advice - furniture layout in odd shaped lounge 7Aug 28, 2015 1:53 pm I'd consider building two walls onto the back of the entry wall, to form a triangular storage cupboard. The TV could then go on the new living wall. To get more wall space, it may even make sense to wall up the opening between the entry and living. Re: Desperate advice - furniture layout in odd shaped lounge 8Aug 28, 2015 2:14 pm I would wall in the entry/Living too, and if I was building a wall I'd knock down that entry wall, make it a straight line and square off the rooms. Straightforward to do, and would eliminate your furnishing issues, while making your 'dining' area much more functional. Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Desperate advice - furniture layout in odd shaped lounge 9Aug 28, 2015 7:27 pm Wow they are such great ideas!!! I love that they will make the space have a more rectangular/ standard shape. Now the fun part, finding builders and getting quotes. Thank you so much, I feel like a weight has been lifted Re: Desperate advice - furniture layout in odd shaped lounge 11Aug 30, 2015 9:01 am bubblynutter I would wall in the entry/Living too, and if I was building a wall I'd knock down that entry wall, make it a straight line and square off the rooms. Straightforward to do, and would eliminate your furnishing issues, while making your 'dining' area much more functional. Top idea! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Desperate advice - furniture layout in odd shaped lounge 12Dec 17, 2015 1:08 am This is really challenging. Shape of the room is quite different. It will be great to work on this project. Check this you will get some ideal. http://bkmoffice.com/ No access to subfloor unfortunatly. I drilled a small hole and missed a stump , I plan is to cut a man hole and do a proper inspection 2 2718 Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 21302 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8653 |
