Browse Forums Interior Decorating Lounge 1 May 31, 2011 7:29 pm How do you remove wallpaper from behind a kitchen counter? We are in the process of stripping wallpaper from our kitchen and dining room and painting. We have successfully removed all of the wallpaper, except for very hard to access areas, where the wallpaper goes down behind our kitchen counters. We have scraped, used wallpaper stripper, and everything else we can thing of to try to remove it, but there are still several small pieces of wallpaper sticking up from behind the counters that are almost impossible to pull out. We are not going to remove the counters, so is there any other method to try?
_____________________________ external keyword tool ~ keyworddiscovery.com ~ keycompete.com ~ compete.com ~ webmasterworld.com Re: How do you remove wallpaper 2May 31, 2011 7:50 pm Possibly try cutting the paper with a Stanley knife? Carefully Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6301 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12496 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7359 |
