Browse Forums Interior Decorating Lounge 1 Jan 14, 2011 3:29 pm I can only talk Dulux here, as I haven't used another brand of paint since making the mistake of using a cheap paint on the stairs and landing of a 3 storey home 12 years ago (you guessed it, re-painted it in Dulux a few moths later!) I have a small bathroom to paint and I imagine that moisture could be an issue. Are the special kitchen and bathroom paints with mold inhibitor worth it? I do everyhting else in low sheen but can I get away with it for the bathroom or should I use the semi-gloss version? Antique white USA is the colour. Re: Bathroom paint - low sheen or semi gloss? 2Jan 14, 2011 4:14 pm Who suggested it??? I’m a Dulux girl here! I always suggest semi gloss for all wet areas. I hear the mold proof paint is pretty good! So I suggest that as well. So yes, semi gloss in mold proof Dulux. In fact I had my ceilings painted in semi gloss right through, much to the disgust of my painter! Who is now a fan of semi gloss on the ceilings…….. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Bathroom paint - low sheen or semi gloss? 3Jan 17, 2011 5:18 pm We used Dulux Mouldshield on our old laundry walls and ceiling. The room was poorly ventilated and we had a real problem with mould. I used the Mouldshield as undercoat on the walls, and just on its own on the ceiling. We weren't there for a long time after - only about twelve months - but it did seem to make a difference. There was no regrowth of the mould in that time, anyway. BTW, I washed the walls down with a weak bleach solution first to kill the existing mould. Re: Bathroom paint - low sheen or semi gloss? 4Jan 20, 2011 4:25 pm acem8 I can only talk Dulux here, as I haven't used another brand of paint since making the mistake of using a cheap paint on the stairs and landing of a 3 storey home 12 years ago (you guessed it, re-painted it in Dulux a few moths later!) I have a small bathroom to paint and I imagine that moisture could be an issue. Are the special kitchen and bathroom paints with mold inhibitor worth it? I do everyhting else in low sheen but can I get away with it for the bathroom or should I use the semi-gloss version? Antique white USA is the colour. Hello??? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Bathroom paint - low sheen or semi gloss? 5Sep 22, 2016 11:12 pm I suggest GALVI ALCOR for mold and semi gloss. https://handel.alcor.pl/pl/p/GALVI-prze ... zienki/357 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 26259 4 6447 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17941 |
