Browse Forums Interior Decorating Lounge Re: Does Surfmist and Colorbond Dune work? 5Jun 27, 2016 9:00 pm I had considered that combination for my new house, but am now considering Evening Haze instead of Dune. To me Surfmist has a slight green undertone, same as Evening Haze. I have seen pics though on this forum of someone using Dulux Beige Royal (perhaps closer to Dune) with Surfmist. Re: Does Surfmist and Colorbond Dune work? 6Jun 28, 2016 6:45 pm Hi Italian Gal, I think Dune and surfmist would work well. Happy to help you out, Do you have an elevation plan? I could pop it in photoshop for you and overlay the colours. THis will give you idea how the colours would work together. Another note; Choosing Charcoal colour roof will add extra heat gain to your home, in such I don't normally recommend any black or charcoal colours. If you're in a cooler climate like VIC or TAS this might be ok, but in area's like WA QLD NT ect really hot extreme summers; this would add a lot more heat to your home. If you still wish to go the charcoal look at devices to cool the roof space down such as whirly birds, increase roof insulation r -rating, even consider a reflective insulation. Hope this helps, Regards, Melinda Re: Does Surfmist and Colorbond Dune work? 7Jun 09, 2019 3:26 pm Lincoln35_mckinley I'd love to know what window coverings you used in your house. We are looking at similar colours but I was still keen to have plantation shutters in some areas. This means white on black windows and I'm not sure how that will go. Re: Does Surfmist and Colorbond Dune work? 8Jun 10, 2019 4:55 pm juliep100 @Lincoln35_mckinley I'd love to know what window coverings you used in your house. We are looking at similar colours but I was still keen to have plantation shutters in some areas. This means white on black windows and I'm not sure how that will go. Hi Julie 😀 We have used a mixture of sheer and blockout rollers plus plantation shutters. We have woodland grey window frames and I think it looks fine. I’ve posted some pictures for you to see. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Does Surfmist and Colorbond Dune work? 9Jun 11, 2019 12:47 am I like Surfmist with Evening Haze better, for what it’s worth. The tones seem to work well together. Re: Does Surfmist and Colorbond Dune work? 10Nov 16, 2019 6:08 am Lincoln35_mckinley juliep100 @Lincoln35_mckinley I'd love to know what window coverings you used in your house. We are looking at similar colours but I was still keen to have plantation shutters in some areas. This means white on black windows and I'm not sure how that will go. Hi Julie 😀 We have used a mixture of sheer and blockout rollers plus plantation shutters. We have woodland grey window frames and I think it looks fine. I’ve posted some pictures for you to see. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi there I'm looking at a Woodland Grey frame as part of a Masterton Home combnation but it looks Olive green in smail display panel which I'm not a fan of. Is that how it looks in your home from the inside against white walls and the outside in the sunlight? I want grey not green. Thank you! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I… 0 6791 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2503 Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 2863 |
