Browse Forums Renovation + Home Improvement 1 Sep 27, 2016 3:48 pm Hello, I been renewing my unit, calling all sort of tradies, with the result of having a "mess wiring system" in my roof cavity. Air conditioning guy laying cables on one place, electrician adding cabled for new down-lights with the result of having a mess in my roof cavity.... Because I am a precise person (my wife would say OCD, while I would say just perfect ) I would like to recall the electrician to "clean up the mess" in the follow way: - install trunking system in the roof cavity to each lights/GPOs from Main Electricity supply - readjust cables so they will sit nicely in trunking system My question is: - is it worth-ed? - is it compliance wit standard? (I am not an electrician and before commissioning one I would like to know if this would be even possible - multiple cable in the same trunking system are going to generate too much eat and "generate a fire hazard"? thanks lots for any answer Re: Trunking System for electric cable in Roof Cavity 2Sep 28, 2016 12:46 pm Quote: Because I am a precise person (my wife would say OCD, while I would say just perfect ) I would like to recall the electrician to "clean up the mess" in the follow way: - install trunking system in the roof cavity to each lights/GPOs from Main Electricity supply - readjust cables so they will sit nicely in trunking system My question is: - is it worth-ed? - is it compliance wit standard? (I am not an electrician and before commissioning one I would like to know if this would be even possible - multiple cable in the same trunking system are going to generate too much eat and "generate a fire hazard"? 1) Nope. Give your OCD a rest and spend the money elsewhere on your apartment. 2) Yes, either way either loose or in a ducting arrangement. 3) Nope, unless either your sparky has installed insufficient sized cables or unless you draw too much load off the circuit By the way your OCD is not too bad. The real obsessives call it CDO - that way even the letters are in alphabetical order ! Stewie For our new build in NSW we opted for a heat pump with a 315L storage tank. Early days yet as we only moved in 6 weeks ago. Haven't run out out of hot water though. Ours… 7 4657 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5870 |
