Browse Forums Renovation + Home Improvement 1 Jul 30, 2016 4:55 pm Hi, we brought our second home near Beachmontroad,Gold cost. Its a good home built in late 1960's. The only problem is that we need to reroof the house. We are using autumn brown from GAF. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I need a good roofing suggestion having same quality. GAF products are good but sometimes it may run over our budget. I am in search of a low budget roofing solution . I welcome any comments on this matter Regards Boris The more you feed your mind with positive thoughts, the more you can attract great things into your life Re: suggest me some low budget roofing solutions . 2Jul 30, 2016 4:59 pm if anybody have experiences with IKO marathon products please share your experience. The more you feed your mind with positive thoughts, the more you can attract great things into your life Re: suggest me some low budget roofing solutions . 3Jan 05, 2017 2:42 am I am still in search of this and found this Polystyrene based thermal Insulation sheets as roofing solution. I read that the strain on the supports are low as this one is light weight. Are they water resistant and durable like metallic roofing? Hope this one is water resistant and is chemically inert? The more you feed your mind with positive thoughts, the more you can attract great things into your life Well these guys are not looking good... I sent them a written enquiry last week and they have not yet replied. If they cannot respond to a simple… 4 11115 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 8327 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3420 |
