Browse Forums Renovation + Home Improvement 1 Jun 05, 2016 9:07 am This is excellent, thanks! I wondered how some people can pull this look off. This makes perfect sense ? Re: how to mix pattern 2Jun 08, 2016 12:06 am Excellent. I just checked out your website too. You do lovely work! Generally, the texture that you listed will have a 2mm size stone chip in it which is dragged with float to give the lines Any patch work needs to be 2mm less than face… 2 1909 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18632 |
