Browse Forums Renovation + Home Improvement 1 Dec 28, 2014 5:26 pm Hi All, I have been researching for hours and cannot find the information that I am after, so I thought it is time to post! I'm planning to build a deck (9.4m x 5.6m) close to the ground using galvanised stirrup posts. I'm trying to work out the bearer and joist sizes. Looking at the span tables it states bearers as 2/90×35, 2/120×35 etc. What does the '2/' stand for? I was thinking about doing this, does it seem right? Bearers 90mm x 90mm - posts span every 1500mm and 1800mm between bearers Joists 90mm x 45mm - 450mm apart Any feedback is appreciated Re: Deck bearer spans for bearers and joists 2Dec 28, 2014 5:37 pm the 2/# means two timbers fixed together so they act together and share the load. For bearers I would use 120x70 instead of 90x90. Same cost but stiffer. If the deck is close to the ground the timbers should be termite and rot resistant. Re: Deck bearer spans for bearers and joists 5Jan 03, 2015 8:40 pm Might want to consult with an engineer but 120*70 as bearers seams like overkill, generally 90*70 HWD of the rack will suffice, otherwise a single 140*45 H3 bearer should suffice, check costs on both. Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9372 Hi Mrboh Just wondering if you have any BAL or flame zone issues on your block, as getting compliance with BAL requirements whilst doing bearers and joists is tough. Not… 1 8645 |
