Browse Forums Renovation + Home Improvement 1 Nov 05, 2014 6:52 pm Any idea how to remove enamel paint from very old, delicate bricks, please? My home was built in 1868. The most recent previous owner painted the red brick quoins. The council's heritage advisor has asked me to remove the paint, which I agree would be best. I'm worried that sand blasting may blast away the bricks as well (there has been salt damp at some stage). Some of the paint is right next to some newly painted timbers. Paint stripper, perhaps? Heat gun? Re: Removing paint from red brick quoins 2Nov 06, 2014 7:41 am I'm surprised the heritage officer didn't advise you on the best way to do this. Failing that I'd contact some other councils and speak to their heritage consultants about your problem. Either that or ask to talk to someone about graffiti removal and what they use. I would have thought a paint stripper would have been best. Some of the low-toxic kind are water based so you would be able to flush them out of the brickwork better than an oil or petroleum based kind. Stewie Re: Removing paint from red brick quoins 3Nov 06, 2014 11:04 am There is a product called Peel Away paint removal. I haven't used it myself but have seen it used many times including on some significant old buildings. It is a combination of a paste and a laminate sheet (kind of like contact) put over the top and left for a few days. The laminate is then pulled of removing the paint. Here is their website: http://www.peelaway.com.au I am not sure of the cost of the system but it must be good because I see it around quite a lot these days. Good luck with it all. Cheers, Jenny. Need hints, tips and inspiration? Join me on my Facebook page: https://www.facebook.com/ournewhomecoach Who am I? See my LinkedIn page: http://www.linkedin.com/pub/jennifer-crawford/1a/429/296 I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6939 The best advice is for you to get a competent building consultant to guide you through your build 7 4992 thanks, yes they are dry , thats a good idea with fish oil as sanding will be hard 4 3366 |
