Browse Forums Renovation + Home Improvement 1 Sep 01, 2014 8:14 pm Re: Help with timber framing lintel 2Sep 01, 2014 8:36 pm To work out the measurements people will need to know what the roof material is going to be. So just to confirm you are saying this is going to be load bearing. Given there is a window I would suspect it is. Also the way you have drawn the studs up against the window is not correct. I think you will need a double stud. Re: Help with timber framing lintel 4Sep 01, 2014 8:48 pm B STAR To work out the measurements people will need to know what the roof material is going to be. So just to confirm you are saying this is going to be load bearing. Given there is a window I would suspect it is. Also the way you have drawn the studs up against the window is not correct. I think you will need a double stud. Just done quick google search for double stud, couldn't find what you mean (2 studs running vertically to side of window?) The timber frames are 140 x 45mm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with timber framing lintel 5Sep 01, 2014 8:57 pm One stud runs from the bottom plate all the way to the top plate, the other runs from the bottom plate to the underside of the lintel to support it.
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How far apart are you running the rafters for the sheet roof - 900mm ? If so you'll need a 275 x 75mm or a 300 x 50 F7 lintel for a roof span of 5100mm or less. A bigger span and you'll need a 300 x 75. Stewie Re: Help with timber framing lintel 7Sep 01, 2014 9:17 pm Stewie D One stud runs from the bottom plate all the way to the top plate, the other runs from the bottom plate to the underside of the lintel to support it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How far apart are you running the rafters for the sheet roof - 900mm ? If so you'll need a 275 x 75mm or a 300 x 50 F7 lintel for a roof span of 5100mm or less. A bigger span and you'll need a 300 x 75. Stewie Stupid me, I see below your diagram you have written some more info. Ill look into rafters but 900mm is a good start cheers Okay so I only have 200mm for lintel so height of walls will need to go up +75 These frames will be for my kitchen Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with timber framing lintel 8Sep 01, 2014 9:21 pm You could get a 200 x 75 lintel in there but it would have to F17 - kiln dried hardwood. Why are you submitting images that are so small we can't see them properly ? Stewie Re: Help with timber framing lintel 9Sep 01, 2014 9:23 pm Stewie D You could get a 200 x 75 lintel in there but it would have to F17 - kiln dried hardwood. Why are you submitting images that are so small we can't see them properly ? Stewie Sorry about the image size, using image shack and it only allows me small thumbnails. Ill do some research and see if I can do it any bigger. 280x 200 all they giving me Re: Help with timber framing lintel 10Sep 01, 2014 9:30 pm Photobucket is better unless there is some way that you can edit the photos on imageshack . The only way I can see them as a full sized image is if I download them first then view them. Stewie Building Standards; Getting It Right! Long story short, a toilet room is going to back onto our main bedroom and I want to make it close to soundproof. Im going to build two frames (pretty much a room within a… 0 11386 STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 6031 8 10253 |
