Browse Forums Renovation + Home Improvement 1 May 18, 2011 4:57 pm Hi All, We have space next to the house where I would like to attach a carport or garage. Above this I would like to add a family room. (Banyule council - Vic) I am expecting that because the carport would go over the existing driveway, I would cut costs significantly versus building a garage which would need a slab, extra walls, etc. Is that a valid assumption? (nb. I would probably do the parralel wall to the house in brick for support, but the two other ends would be open.) The ground is level at and access is ok. I am also trying to a do basic cost estimate the cost of building this (ballpark stuff), and don't know if adding a room 30sqm that just has electricty, insulation, windows etc. (I.e. no plumbing, no kitchens etc) would cost 50k or 150k.... My expectation is about 80k for a nice family room. Any input is greatly appreciated! Thanks David Re: Advice on addition of a carport and room above 2May 18, 2011 6:08 pm Hi What you propose seems reasonable but by the time you have excavated for decent foundations for the outside wall I don't know how much of the driveway will be left. I would have thought you should be able to do something reasonable for $80,000 but a lot will depend on issues with the roof and how you connect that to the existing roof. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Advice on addition of a carport and room above 3May 18, 2011 6:18 pm Dave, 1. You can't use the carport slab to support the addition. They are only about 100mm thick. You have to look at this as though the driveway is not there. 2. You are just building a structure that is open underneath. There are no savings. 3. A masonary wall (ie, bricks) gives no structural advantage over a timber framed wall. It is still holding up the roof. 4. Therefore you are just putting on an addition without a bathroom, and 2400mm off the ground. Say $1200-1500/m2. Paul Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building… 0 5164 |
