Browse Forums Renovation + Home Improvement 1 Feb 20, 2024 11:14 am We have a working fireplace with dark slate tile. We want to smooth it out and paint it white without losing all of the skirting and finishing around it. Ideally we'd remove the tiles but we've been told that is not really possible. We've also been suggested to concrete it then it'll be smooth and paintable. What's the best way to do this? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Smooth out / remove slate tile fireplace 2Feb 23, 2024 4:05 pm robbie762 We have a working fireplace with dark slate tile. We want to smooth it out and paint it white without losing all of the skirting and finishing around it. Ideally we'd remove the tiles but we've been told that is not really possible. We've also been suggested to concrete it then it'll be smooth and paintable. What's the best way to do this? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I would probably render it and then paint it as per your other advice, or gyprock over the top. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 919 just pull up the slate. If you go over the top, your tiles would not have an even surface to be glued to. Im no tiler, but i can imagine a couple of things being an issue… 1 675 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 14031 |
