Browse Forums Renovation + Home Improvement 1 Oct 01, 2023 2:43 pm Hi All New here and need your advice please. We are doing renos in a few months and we just got our quote from the builder which is a 100k over our budget. Hubby wants me to give up the plans for the new hallway as this is the reason the cost is up as it means redoing a lot of the roof to facilitate the hallway. At the moment there is no hallway. I'm keen for advice on hallway alternatives - I always wanted one as I thought it makes it a home? When you open the existing front door as marked in image you walk straight into living area. The garage will be knocked and sitting room extended. Please help Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Alternative to hallway? 2Oct 22, 2023 12:29 pm Nov24 Hi All New here and need your advice please. We are doing renos in a few months and we just got our quote from the builder which is a 100k over our budget. Hubby wants me to give up the plans for the new hallway as this is the reason the cost is up as it means redoing a lot of the roof to facilitate the hallway. At the moment there is no hallway. I'm keen for advice on hallway alternatives - I always wanted one as I thought it makes it a home? When you open the existing front door as marked in image you walk straight into living area. The garage will be knocked and sitting room extended. Please help Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ please share the plans for the proposed alterations and a google earth view the existing roof to help explain the problem with the new hallway at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61661 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8840 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 2660 |
