Browse Forums Renovation + Home Improvement 1 Jun 04, 2023 8:57 pm Hi all! I am about to start replacing some of the brick piers in the downstairs section of the house with 90x90 timber posts, in line with my engineer's design. Once the piers are replaced we will pour a concrete slab which we will then finish with a floating floor. My question is as to whether anybody has completed a similar exercise in the past? If so, do you have any tips, or additions to the stages in the attached pdf which would provide a better / more durable end result? Thanks for your assistance in advance! Photo links: https://ibb.co/F6jQDYY - Stage 1 - Existing Condition https://ibb.co/K6vMNzB - Stage 2 - Post installed https://ibb.co/sqf4tqd - Stage 3 - Slab poured Re: Brick pier replacement methodology / tips 2Jun 06, 2023 9:45 pm Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12339 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 47355 |
