Browse Forums Renovation + Home Improvement 1 Mar 07, 2023 6:59 am Hello everyone. I am a new member and this is my first time posting. I checked almost all available topics on stormwater system however didn't find answer to issue I have. I need to know correct procedure on building a new stormwater system and estimated costs. I have an existing easement at my backyard and when I talked to my local council (Blacktown NSW) they said I have the rights to connect to that easement as it is inside my property and I can just ask my plumber to connect to that. Is it that simple? I am hearing it has to be designed first and then plumber will build based on that design. Any help and advise will be greatly appreciated. Re: Stormwater system 2Mar 07, 2023 8:53 am rizi25 I need to know correct procedure on building a new stormwater system and estimated costs. I am hearing it has to be designed first and then plumber will build based on that design. Any help and advise will be greatly appreciated. See if you can find at Hydraulics 3D Bim guy (Design Engineer). They can design, certify and provide data and estimates. Then get 3 plumbers to quote OT, I checked out a processing plant being built here last week the futures already here, mate Pity engineering forums aren't open to the public, plenty of graduates looking for extra weekend cash Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwater system 3Mar 07, 2023 10:31 am Talk to a drainer (or three) and ask for a quote. It is that simple! 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater system 5Mar 07, 2023 3:18 pm That must be a council requirement then which is very unusual if it is a bog standard system. Stormwater just needs a 1:100 fall for the standard run of the mill size pipes (but less for larger pipes), there is nothing to design for the connection to the LPOD. Who told you an engineer has to design it and what classification of engineer did they reference? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater system 6Mar 08, 2023 10:08 am SaveH2O That must be a council requirement then which is very unusual if it is a bog standard system. Stormwater just needs a 1:100 fall for the standard run of the mill size pipes (but less for larger pipes), there is nothing to design for the connection to the LPOD. Who told you an engineer has to design it and what classification of engineer did they reference? There's a plumber I talked to and he advised it needs to be designed by a hydraulic engineer before he can lay down pipes and connect to existing easement. I have a company quoted me below.
Fee: $3,600 + GST Does each council have different requirements? I emailed my local council and asked the question, still waiting for reply though. Re: Stormwater system 7Mar 08, 2023 10:18 am Ouch...I've got to put my rates up? (humour) Try a civil/construction engineer.. shop around OT, No wonder you guys in sydney can't afford basic housing Here we bundle the stormwater in the DA application " cheap as chips" so you know what's included After you've signed with a builder , that may not be the case Forewarned is forearmed Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwater system 8Mar 08, 2023 1:50 pm Even with the added rigmarole, they are most likely charging for 30 hours work at $120 hr but there isn't 30 hours work in what is described unless artwork costs have gone through the roof. Hydraulic engineers in general earn about $2.4k per week but company overhead and profit costings can double their hire out fee. You can only shop around for other quotes but look for a private operator who won't rort you on the hours the work requires. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 5572 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8986 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 8165 |
