Browse Forums Renovation + Home Improvement 1 Oct 28, 2022 1:04 pm We have recently bought a weatherboard house in Melbourne western suburbs. Existing house is old weatherboard house in good condition with not much work required inside or outside except the roof need seal/paint. I am planning to extend the house in the rear (single story) by 95 SQM that includes 3X8.65 SQM alfresco outdoor area so 69 SQM indoor. Soil test report states that we might encounter big rocks (floaters/boulders, weathered basalt / basalt bedrock). I am starting to fear that we might have significant cost for excavation and removal of rock. How much $ i should allocate for excavation and removal of rock? During excavation - will there any impact to the house in the front - on concrete stumps? Access to the rear is through side driveway - 2.5 meters - will this become an issue? Appreciate your help! Re: Extension - weatherboard house / rock excavation questio 2Oct 30, 2022 9:42 am Hi, Is the site sloping and are you digging out material to lower the ground level or just digging for new footings? If bulk excavation to lower ground level, rock excavation rates should be specified in the contract. If just for footings, if rock is encountered they will put footings on top. Sometimes site classification reports say rock might be encountered because they didn't achieve 3m depth and the actual proposed construction isn't considered. Impacts from bulk rock excavation usually only due to vibrations where big machines used near existing sensitive structures. A single storey weatherboard house on stumps wouldn't be expected to be affected. Re: Extension - weatherboard house / rock excavation questio 3Oct 30, 2022 10:42 am Thanks for your response . You are correct - they couldn't achieve 3m depth - couldn't go longer than 900 mm - hit with hard base by 900 - assumed floaters. Excavation is not to lower ground level. It's just for the new footings! Thanks for the clarification that if rock is encountered, they will put footings on top. No one can give you a meaningful answer without looking at your building contract, what happened on site and who designed your house You should get experienced building… 1 10388 Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building… 0 5171 We just had a pool dig and was told by our contractor the pool would need piers. They spoke to the engineer who advised the piers would need to be concrete. When the… 0 1044 |
