Browse Forums Renovation + Home Improvement 1 Sep 07, 2022 11:01 pm Need advice - Having rendering on 30 year old home and renderer said we can not render the expansion joint as it is not good for house. I am little lost as it is not looking good .. expansion joints are quite big and visible. Question is - Is it wrong to fill rendering joint? If yes any suggestion on how to get better look? If not, how to fill that as it is big in size compared to new houses I have seen. First photo of showing expansion join and second of what has been done so far . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rendering and expansion joint 2Sep 08, 2022 8:08 am You don't render over expansion joins. They are to be left free of render. Dark matter scientist, can breathe underwater, mind reader andย can freeze matter just by willing it. Trust me, its in my sig. Re: Rendering and expansion joint 4Sep 08, 2022 8:44 am Jamesmao Thanks, so expansion joints to be left like that?.. looks really bad ๐ yes, and it looks normal. Usually when the house is built, if they render, they match the sealant colour in the join as close as possible to the render colour, but they are always visible. In your case, If the colour is matching the brick under the render and not the render you can remove the old sealant and reseal with something closer matching the render, but this i a pain to do and you are likley to still not be happy. Take a walk around any new suburb where there is heaps of rendered houses and you will see its quote normal. You'll forget its there soon. Dark matter scientist, can breathe underwater, mind reader andย can freeze matter just by willing it. Trust me, its in my sig. Re: Rendering and expansion joint 5Sep 08, 2022 11:24 pm Noname Jamesmao Thanks, so expansion joints to be left like that?.. looks really bad ๐ yes, and it looks normal. Usually when the house is built, if they render, they match the sealant colour in the join as close as possible to the render colour, but they are always visible. In your case, If the colour is matching the brick under the render and not the render you can remove the old sealant and reseal with something closer matching the render, but this i a pain to do and you are likley to still not be happy. Take a walk around any new suburb where there is heaps of rendered houses and you will see its quote normal. You'll forget its there soon. Thanks heaps. I will follow that. Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4858 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2915 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5473 |
